OR in automation for JIRA
Petr Nový
Hello, is it somehow possible to use OR operator when using multiple conditions in Automation for JIRA?
Michelle Gronwold
Not sure if you found help, but this link helped me solve for a similar problem I was having. Assigning issues using an if/else condition.
How to auto assign issues with Jira automation | Atlassian
ddubrava
July 4, 2025
It looks that "if / else" or multiple "issue fields condition" do not support OR. You can use "JQL condition" instead. For example, `component is EMPTY OR labels is EMPTY`
Ste Wright
Hi @Petr Nový
What are you trying to achieve?
I'm not sure if it is possible to move from AND to OR - but it might still be possible to create what you're looking for the rule to do using an alternative method.
Ste
Petr Nový
Hi @Ste Wright ,
Thanks for reaching out. I would like to create rule which will trigger on comment which occurs in
  • In certain project
  • OR by certain creator, regardless on project
  • OR with certain comment properties, regardless on conditions above.
So far, I have created multiple independent rules, with same outcome. This is not great solution, as
  1. Multiple rules may trigger simultaneously -> multiplying outcome.
  2. It is difficult to maintain.
  3. It have performance drawbacks, as 3 (possibly asynchronous?) rules will be triggered for one event.
Therefore single rule with complex condition would be much better. I just dont know how to do it  :-)
Thanks in advance
Petr
Like # people like this
Petr Nový
Hi @Ste Wright ,
Thanks for reaching out. I would like to do certain action when an issue is commented in one of following conditions:
  • Issue is in certain project
  • OR issue is being commented by certain user
  • OR comment have specific comment property.
So far, I have created multiple independent rules - one for each OR condition. it have several drawbacks:
  1. Extensive maintenance - changing outcome have to be updated for multiple rules.
  2. Performance - 1 listener is better than 3
  3. It can potentially trigger multiple times, possibly duplicating the  outcome.
Therefore it would be best to have only one automation rule for this. I just do not know how to achieve that :-)
Thanks in advance
Petr
Darryl Lee - CCC
I think you have to use a JQL condition:
```project=FOO OR reporter="VIP"```
Ste Wright
Hi @Petr Nový
Apologies for not coming back to you on this question!
In case this is still needed, you can create an "OR" statement utilising Else/If. You can create multiple layers (more than two) using this condition, and it should avoid duplicate actions unlike multiple rules.
See how to utilise Else/If on this page.
Ste
Oleksandr.Ruzhylo
Hello all.
Is it possible to use the following structure:
(Condition 1) AND (Condition 2 OR Condition 3).
Where Condition 1 is mandatory.
How it's possible to implement?
Like Sylvain Chabot-Beaulieu likes this
Ste Wright
Hi @Oleksandr.Ruzhylo
It should still be possible using IF Block - eg.
  • Trigger: Issue Created
  • Condition 1: ...
  • Condition 2/3: IF Block
    • IF...
      • Run actions if = At least one condition matches
        • Condition 2
        • Condition 3
  • Action: ...
^ The first condition must happen, it's a requirement to get to 2/3.
But the IF Block can be set to be either/or - so if either are true, then the action runs
Ste
Katie Downing-Powell
October 10, 2024
This would be a very useful function for my organization, as well.
Sandro Winkler
July 17, 2025
Hi @Ste Wright
How do you change the IF block to "either/or"? There is no option for that
