Prevent issue to be moved into a specific project
Fredrik Ivansson Flinta
Is there a way to prevent issues to be moved into a specific project?
Move or Create permissions is not useful in the case.
In the UseCase almost all users are in the jira-software-users with the ability to create and move.
We have both Automation for Jira and Scriptrunner installed.
Nic Brough -Adaptavist-
October 22, 2021
The only way to stop an issue being moved into a project is to take away the person's right to create issues in the project.
Thank for the answer @Nic Brough -Adaptavist- .
I found a solution for it by creating a custom listener in Scriptrunner, so there are other solutions for it ;)
Also found out that in Automation For Jira there is a trigger for issue moved.
Fábio Ferreira
July 25, 2022
Hi   @Fredrik Ivansson Flinta
Can you provide the listener solution :) .
SERVER
VERSION
8.13.11
