Problem with embedding Google Charts with a Scriptrunner Custom Field
flaimo
I have created a custom field that outputs a google chart based on some data from the issue. This works so far, but there is a side effect, that I cannot browse issues anymore, as soon as an issue is selected that contains the chart. The UI looks deactivated (see screenshot).
I guess it has something to do with the javascript from google, but I don't know how to solve this. Any ideas?
Code:
import com.atlassian.jira.issue.search.SearchProvider
import com.atlassian.jira.jql.parser.JqlQueryParser
import com.atlassian.jira.web.bean.PagerFilter
def jqlQueryParser = ComponentAccessor.getComponent(JqlQueryParser)
def searchProvider = ComponentAccessor.getComponent(SearchProvider)
def user = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
def counterToDo = 0
def counterInProgress = 0
def counterDone = 0
def currenIssueStatusCategoryName = ''
def returnstring = ''
Stories directly under the initiative
def queryString = "issueFunction in linkedIssuesOf('issue = " + issue.getKey() + "', 'derives') AND issuetype != Epic"
def query = jqlQueryParser.parseQuery(queryString)
def results = searchProvider.search(query, user, PagerFilter.getUnlimitedFilter())
results.getIssues().each {documentIssue ->
currenIssueStatusCategoryName = documentIssue.getStatus().getStatusCategory().getName()
if (currenIssueStatusCategoryName == "New") {
counterToDo += 1
} else if (currenIssueStatusCategoryName == "In Progress") {
counterInProgress += 1
} else if (currenIssueStatusCategoryName == "Complete") {
counterDone += 1
} // end if
} // end each
Stories in epics
queryString = "issueFunction in linkedIssuesOf('issue = " + issue.getKey() + "', 'derives') AND issuetype = Epic"
def epicString = ''
if (results.total > 0) {
epicString += documentIssue.getKey() + ','
} // end each
queryString = "issueFunction in issuesInEpics ('issuekey IN (" + epicString.substring(0, epicString.length() - 1) + ")')"
counterToDo += 1
counterDone += 1
} // end if
} // end each
} // end if
if (counterToDo > 0 || counterInProgress > 0 || counterDone > 0) {
returnstring = """<script type='text/javascript' src='https://www.gstatic.com/charts/loader.js'></script><div id='chart_div'></div>
<script type='text/javascript'>
google.charts.load('current', {packages: ['corechart', 'bar']});
google.charts.setOnLoadCallback(drawBasic);
function drawBasic() {
var data = google.visualization.arrayToDataTable([
['Status Category', 'ToDo', { role: 'annotation' }, { role: 'style' }, 'In Progress', { role: 'annotation' }, { role: 'style' }, 'Done', { role: 'annotation' }, { role: 'style' }],
['Issues', ${Integer.toString(counterToDo)}, ${Integer.toString(counterToDo)}, '#396886', ${Integer.toString(counterInProgress)}, ${Integer.toString(counterInProgress)}, '#ffd144',${Integer.toString(counterDone)}, ${Integer.toString(counterDone)}, '#008e27']
var options = {
width: '99%',
height: 20,
chartArea: {'width': '100%', 'height': '100%'},
legend: { position: 'none' },
bar: { groupWidth: '100%' },
isStacked: 'relative',
hAxis: { textPosition: 'none', direction: -1,format: 'percent' },
vAxis: { textPosition: 'none' },
annotations: {
textStyle: {
fontSize: 12,
color: '#fff',
opacity: 0.5
backgroundColor: {
fill: 'transparent'
var chart = new google.visualization.BarChart(document.getElementById('chart_div'));
var c_div = document.getElementById('chart_div');
chart.draw(data, options);
</script>
return returnstring.replaceAll(/ /, '');
} // end if
flaimo
Kamran Ansari August 16, 2021
@flaimo
Were you able to get past this issue? I'm running into it and was wondering how you fixed it.
Many thanks,
Kamran
