×Greetings:
I have a service project in Jira 8.1 and Service Desk 4.1 , but I can't see the SLA menu, edit the Request Type (as describe in the manual , also the screen is diferent) and others option from the project management sidebar like the documentation says;
1.- This is the documentation picture
2.- This is my project.
Before this I used Jira 7.2 and Service Desk 3.2 and never had this problem. Also I have all the permissions as admin.
I hope to be clear.
Thanks.
Hi , anyone have the same issue. The only thing that's try it's reinstall everything
It is most likely a permission issue. Make sure you have a license for Jira Service Desk associated with your account. You may also need to add yourself as an agent on that project to get all of the service desk functionality.
Hi Brant:
Thanks for answer, i have all the permissions and my user is a agent for the project but it didint work.
Can you send me a screenshot of the user roles section of the project.
Hi , Any idea? I installed the same version of jira in another pc and I can see SLA and edit the request , having the same permissions as I showed before.
