Project workflow / Post-Functions
Hlib Zhurakovskyi March 17, 2021
Greetings!
I want to automize my Workflow. These is one feature wich can help me with is but I can`t find approach with it:)
Its about collaboration of transition to status and post function at custom fields (CF).
I`ve created status "Reviewed" (transition from status "Code Review") and CF "Reviewers" (User Picker (multiple users)).
The main goal is autofilling this field with the name of user when he doing the transition.
Moreover, there is a special macros:
'%%CURRENT_USER%%'
But it doesn`t work.
Has someone the same issue or a way to fix this issue?
Screenshots:
https://prnt.sc/10obb6b
https://prnt.sc/10obcfn
Fabio Racobaldo _Catworkx_
Hi @Hlib Zhurakovskyi ,
welcome to the community. Try to setup %%CURRENT_USER%% and not '%%CURRENT_USER%%' (with single quotes) on the custom field value. This should fix your issue.
Fabio
Hi!
I`ve tried %%CURRENT_USER%%, '%%CURRENT_USER%%' and %%%%CURRENT_USER%%%%. Found this variations on the web.
Did u fix your issue?
Unfortunately, no
I just tested my solution in my dev environment and it works!
Please verify that you checked "Append value"
Oh, nice, it works.
Now what macro should i use to add current user instead replace?
Thanks for your help BTW!!
The user that will perform the action will be added to that field.
Please, accept my answer so that this question is marked as solved.
Ciao,
Fabio
Dhruvin Patel June 15, 2022
what is the name of that post function?
Malik Waqas March 17, 2021
Goodness, pleasant, it works.
Presently what full scale would it be advisable for me to use to add current client rather supplant?
A debt of gratitude is in order for your assistance BTW!!
Hi @Malik Waqas ,
happy that it helped! If you check append, user will be added to the list without removing previous users.
Fabio
