Question regarding SQL query for Custom fields
HaRsHaS_ V April 7, 2020
I am trying to put the custom field data on a confluence page for an instance-that includes custom fields, their values and issue types.
The page should contain the details and it should be updated when ever we make any change to the instance-for example if we add a new custom field it should be updated auto on the confluence page.
Please suggest me any SQL query for this?
Nic Brough -Adaptavist-
April 8, 2020
No, don't use SQL to do this, you'd need to write a complex macro to get it to run every time you refreshed or visited the page, and the SQL would be inefficient.
Why don't you just use the Jira issues macro?
HaRsHaS_ V April 8, 2020
@Nic Brough -Adaptavist- , thanks for responding. So, Jira issue macro will just just an list of issues and it is dynamic in nature
Let me give you a background. I am working on a documentation, where we are trying to keep just the configuration details
example 1: projects-issue types used
example 2: custom fields> Field values> type of field> issue types associated.
This is what i am looking for..I know its crazy...if any more thoughts..would appreciate it.
But thanks for the reply-appreciate it!!.
