Resolve issue based on other issue status
Rigo
Hi all,
I am trying to resolve an automation error. The error is 'no fields or field values to edit for issues (could be due to some field values not existing in a given project).
My rule logic is below. I suspect the difference in statuses is the reason for my error.
I have two projects that have different statuses.
  1. HELP
  2. USFSC
Objective: When I resolve an issue in the USFSC project if there is a linked 'relates to' issue I want to resolve the HELP project issue.
John Funk
Hi Rodrigo,
That typically means that the field to update is not on the Edit screen or is not a part of the context for the field does not include the project and/or issue type used for the issue being processed.
Rigo
Hi John,
Thanks for the quick reply! These two projects do have different issue types! Meaning that this isn't possible right? The only issue field I'm trying to update is the status.
John Funk
It's possible but make sure the context for the custom field uses both issue types.
Rigo
Thanks John. Although, I am not using a custom field. I am trying to do this with the regular status field.
John Funk
You are trying to update the Status field? Why wouldn't you do an Transition Issue instead?
Rigo
I tried to transition in the issue in the past but no luck. I don't have the error from the past but I have just tried with the new action of a transition and its now working!
I appreciate all the help sir!
Like John Funk likes this
John Funk
Great! Glad it is working!
