×Hello.
I am Working with Atlassian Applications.
I have a machine, where I have installed:
- Jira v7.3.9 + Jira Service Desk v3.5.3
- Confluence v6.7.1
- Apache HTTP Server v2.4.33
Initially I was able to access both apps like this:
JIRA -> http://hostname:8080
Confluence -> http://hostname:8090
However I configured APache HTTPServer (reverse proxy) so that I could access both of the apps like this:
JIRA -> https://servicedesk.domain.com
Confluence -> https://kb.domain.com
And I can confirm that I can access both apps, like this.
-> This are my connectors, in Jira server.xml:
<Connector acceptCount="100" bindOnInit="false" connectionTimeout="20000" disableUploadTimeout="true" enableLookups="false" maxHttpHeaderSize="8192" maxThreads="150" minSpareThreads="25"
port="8080" protocol="HTTP/1.1" useBodyEncodingForURI="true"/>
<Connector SSLEnabled="true" acceptCount="100" clientAuth="false" connectionTimeout="20000" disableUploadTimeout="true" enableLookups="false" maxHttpHeaderSize="8192" maxSpareThreads="75" maxThreads="150" minSpareThreads="25" port="8443"
protocol="org.apache.coyote.http11.Http11NioProtocol" scheme="https" secure="true" sslProtocol="TLS" useBodyEncodingForURI="true"
keyAlias="my_alias" keystoreFile="C:\Program Files\Atlassian\file.pfx" keystorePass="changeit" keystoreType="JKS"/>
-> This are my connectors, in Confluence server.xml:
port="8090" protocol="HTTP/1.1" useBodyEncodingForURI="true"/>
<Connector port="9443" maxHttpHeaderSize="8192" maxThreads="150" minSpareThreads="25"
protocol="org.apache.coyote.http11.Http11NioProtocol" enableLookups="false" disableUploadTimeout="true" acceptCount="100" scheme="https"
secure="true" clientAuth="false" sslProtocols="TLSv1,TLSv1.1,TLSv1.2" sslEnabledProtocols="TLSv1,TLSv1.1,TLSv1.2" SSLEnabled="true" URIEncoding="UTF-8"
-> This are my virtualhosts, in Apache httpd.conf:
<VirtualHost *:80>
ServerName servicedesk.domain.com
Redirect permanent / https://servicedesk.domain.com
ProxyRequests Off
ProxyPreserveHost On
<Proxy *>
Require all granted
</Proxy>
</VirtualHost>
<VirtualHost *:80>
ServerName kb.domain.com
Redirect permanent / https://kb.domain.com
ProxyRequests Off
<Proxy *>
Require all granted
</Proxy>
ProxyPass /synchrony http://hostname:8091/synchrony
<Location /synchrony>
Require all granted
RewriteEngine on
RewriteCond %{HTTP:UPGRADE} ^WebSocket$ [NC]
RewriteCond %{HTTP:CONNECTION} Upgrade$ [NC]
RewriteRule .* ws://hostname:8091%{REQUEST_URI} [P]
</Location>
</VirtualHost>
-> This are my virtualhosts, in Apache httpd-ssl.conf:
<VirtualHost *:443>
DocumentRoot "c:/Apache24/htdocs"
ServerName servicedesk.domain.it
ErrorLog "c:/Apache24/logs/error.log"
TransferLog "c:/Apache24/logs/access.log"
SSLEngine on
SSLCertificateFile "c:/certification/domain.com.crt"
SSLCertificateKeyFile "c:/certification/domain.com.private-key.text"
BrowserMatch "MSIE [2-5]" \
nokeepalive ssl-unclean-shutdown \
downgrade-1.0 force-response-1.0
CustomLog "c:/Apache24/logs/ssl_request.log" \
"%t %h %{SSL_PROTOCOL}x %{SSL_CIPHER}x \"%r\" %b"
SSLProxyEngine On
ProxyRequests Off
ProxyPass / https://hostname:8443/
ProxyPassReverse / https://hostname:8443/
</VirtualHost>
<VirtualHost *:443>
ServerName kb.savethechildren.it
SSLEngine on
SSLProxyEngine On
ProxyRequests Off
ProxyPass / https://hostname:9443/
ProxyPassReverse / https://hostname:9443/
</VirtualHost>
Now, I followed some Atlassian posts off how to do this:
https://confluence.atlassian.com/confeap/administering-collaborative-editing-847355676.html
https://confluence.atlassian.com/confeap/using-apache-with-mod_proxy-480346967.html
At this point I can access both Jira and COnfluence through this urls:
My issue is that I cannot edit documents in Confluence due to a synchrony error.
When I try edit a document I get:
" VM420:1705 WebSocket connection to 'wss://kb.domain.com/synchrony-proxy/v1/bayeux-sync1' failed: Error during WebSocket handshake: Unexpected response code: 200
VM420:540 Synchrony: Warning: reconnect (Transport.handshakeOverXhr: ws connection failed, and cross-origin-long-polling is disabled) ".
I think It's because my APache config and I missing something for Synchrony.
In the last weeks, I have tried a lot of things but I still couldn't do this.
Can anyone help me with this please?
yep, that fixed it for me as well.
# a2enmod proxy_wstunnel
# systemctl restart apache2
There is a bunch of stuff for other Atlassian apps in my Apache config but this is the relevant part for Synchrony.
ProxyPass /synchrony http://localhost:8091/synchrony
ProxyPassReverse /synchrony http://localhost:8091/synchrony
Require all granted
RewriteEngine on
RewriteRule .* ws://localhost:8091%{REQUEST_URI} [P]
</Location>
Please try adding this in your apache.
Require all granted
RewriteEngine on
RewriteRule .* ws://ipaddress:synchronyport%{REQUEST_URI} [P]
</Location>
I try adding that to my <Virtualhost:443>, but I still have the same issue.
Now It looks like this:
#Confluence
<VirtualHost *:443>
ServerName kb.domain.it
SSLEngine on
SSLCertificateFile "c:/certification/domain.it.crt"
SSLCertificateKeyFile "c:/certification/domain.it.private-key.text"
SSLProxyEngine On
ProxyRequests Off
Require all granted
RewriteEngine on
</Location>
</VirtualHost>
Do you have any more ideas about this issue?
1.In the network tab can you filter with bayeux and see what is the response code.For synchrony to work this should give 101 response.
2.Are you hosting synchrony in same machine,if yes have to trouble shoot whether the port is open and any other error from synchrony log.
I'm having the exact same issue that the OP is talking about:
WebSocket connection to 'wss://confluence.example.com/synchrony-proxy/v1/bayeux-sync1' failed: Error during WebSocket handshake: Unexpected response code: 200
What proxy you have infront of confluence?.Are you running synchrony in same server.
