How SQL request I must write for jira issues moved from my project?
I was install plagin NFeed, and want to write in the Query-SQL script or maybe JQL request if is possible - for moved issues from project (key = KSP)
There is a table with a pretty obvious name - it is something like moved_issues (but don't quote my memory on that)
You'll find it has "old issue key" (the project-sequence key the humans use) then "issue id" (The unique immutable key in the database that does not change when you move the issue to another project)
In general, the user set a task, write a Filter that will show the number of issues moved from our project to anywhere, for a week from 00.00 on Monday.
But I can't find in JQL filter this function with - show the number of issues moved
And write this SQL script in the plagin NFeed
Select project.pkey + '-' + cast(jiraissue.issuenum as varchar(20)) as issueKeyForJQL , jiraissue.issuenum , changeitem.* from jiraissue join project on jiraissue.PROJECT = project.ID join changegroup join changeitem on changegroup.ID = changeitem.groupid on jiraissue.ID = changegroup.issueid where project.pkey = 'KSP
But I must write jql filter for user...And dont understand how.
I think i must write my custom function, for moved issues ?
You are correct, you will need a custom function for that. Annoyingly, Jira has a "issue was ..." search function, but it does not yet support "project", so you can not yet issue searches like "Project was xyz"
Do you have any of the scripting add-ons? Or would you be aiming to write a JQL function as an add-on for yourself?
In our JIra system we using Script Runner, nFeed plugin.
I must write this filter -- Filter that will show the number of issues moved from our project to anywhere, for a week from 00.00 on Monday.
But in JQL cant find some function in our system
This Filter will be used our Project Manager for filtering issues...
Not a direct answer but here are my thoughts FWIW.
Not sure about SQL but you can't get there via JQL AFAIK. The previous issue key will be stored in the history and you might consider writing a listener for moves and storing the old key in a custom field. Then you can search for not empty on that field. You can also achieve via Scriptrunner I expect.
Sorry, but I dont know how write listener(((
I dont know groovy and java(((
