ScriptRunner Automation for Jira
adir sinai
August 22, 2022
Hey community,
Having a problem to execute a script form a file.. getting the error - "
Please enter the code to execute or the path to a file".
The path is ok, the file is on the files server and the script works perfect when I using the script option.
Those anyone having this problem too?
Thanks!
Radek Dostál
August 22, 2022
Without seeing the paths all we can do is to provide moral support.
Script Roots are described here so perhaps you're using a wrong folder: https://docs.adaptavist.com/sr4js/latest/best-practices/write-code/script-roots
adir sinai
August 23, 2022
Thanks for your answer!
After reading this, the problem is still the same... There are the paths (before and after)
everything looks just fine but still got the same error. Do you have any idea?
Joshua Steubs August 26, 2022
Any success in fixing this? We're experiencing the exact same issue.
We've successfully created rules with scripts very recently (as recent as a couple weeks ago). We're experiencing this issue both in our dev and prod environments.
Bastian Tschacher
August 29, 2022
Same problem here now.
Joshua Steubs August 30, 2022
I've raised this with Midori support, hopefully it's resolved soon.
Like # people like this
Pavel Kapinos September 2, 2022
The same problem
Bastian Tschacher
September 15, 2022
Any news on this?
Joshua Steubs October 17, 2022
Sorry, not much news on this. We reached out to Atlassian support and it seemed to just start working again one day. Didn't look into it further as it's a small issue for us.
In case anyone comes across this and needs a quick and dirty "workaround", we just used the SCRIPT tab and pasted our scripts there. Bit of a pain to maintain, but seems to work fine.
Normann P_ Nielsen _Netic_
January 9, 2023
I have the same problem :-(
Nicolas Seronvalle
Hello, we have exactly the same issue. We will raise a support ticket but in the meantime, has anyone any update/news about this problem?
Michal Patoprsty March 3, 2023
Hi @Nicolas Seronvalle
I had the same problem and it was fixed in new version of scriptrunner 7.0.0.
More info:
https://productsupport.adaptavist.com/browse/SRJIRA-6060
