Dear all,
I know it is a very global question: is there a way to speed-up the execution of scriptrunner scripts.
it is a very simple script.
Elapsed: 2084 ms
CPU time: 1313 ms
Server:
JVM:
Any tips or advice?
Matt
Hi Matt,
Sorry to hear that about your bill :-).
import com.atlassian.jira.issue.IssueManager;
import com.atlassian.jira.issue.MutableIssue;
import com.atlassian.jira.ComponentManager;
import com.atlassian.jira.event.type.EventDispatchOption;
void setSummary(String key,String newSummary) {
    try{
        ComponentManager componentManager = ComponentManager.getInstance();
        IssueManager im = ComponentAccessor.getIssueManager();
        MutableIssue issue = im.getIssueObject(key);
        issue.setSummary(newSummary);
        im.updateIssue(ComponentAccessor.jiraAuthenticationContext.getLoggedInUser(), issue, EventDispatchOption.DO_NOT_DISPATCH, false)
    }catch(Exception ex){
        log.error(ex);
def cfCustomerRequestType = ComponentAccessor.customFieldManager.getCustomFieldObject("customfield_10001")
def customerRequestTypeValue = (String) issue.getCustomFieldValue(cfCustomerRequestType)
def crt = "";
switch(customerRequestTypeValue){
    case "sd/c0e84f82-b0fa-4455-a35b-459a4482008a":
        def cfFirstName = ComponentAccessor.customFieldManager.getCustomFieldObject("customfield_10802") //File share access
        def firstNameValue = (String) issue.getCustomFieldValue(cfFirstName)
        def cfLastName = ComponentAccessor.customFieldManager.getCustomFieldObject("customfield_10803") //File share access
        def lastNameValue = (String) issue.getCustomFieldValue(cfLastName)
        crt = "("+firstNameValue+" "+lastNameValue+")";
    break;
    case "sd/ffcd2750-6df1-4dad-a6b4-d97375dac5f0":
        def cfName = ComponentAccessor.customFieldManager.getCustomFieldObject("customfield_12600") //File share access
        def NameValue = issue.getCustomFieldValue(cfName)
        def cfFileShare = ComponentAccessor.customFieldManager.getCustomFieldObject("customfield_11501") //File share access
        def fileShareValue = issue.getCustomFieldValue(cfFileShare)
        crt = "("+NameValue[0].getName() + " - " + fileShareValue[0].getName() +")";
    break;
    case "sd/69293647-7944-470b-b2ee-c02643560a51":
        def cfApplication = ComponentAccessor.customFieldManager.getCustomFieldObject("customfield_11202") //File share access
        def ApplicationValue = issue.getCustomFieldValue(cfApplication)
        crt = "("+NameValue[0].getName()+ " - " + ApplicationValue[0].getName() +")";
    break;
    case "sd/systemproblem": crt="Report a system problem"; break;
    case "sd/d4e8d12b-f6c7-4c45-a5f2-98d6ffae1efd": crt="Login issue"; break;
    case "sd/d624ae3d-dca1-4d95-b660-053f93f9fe53": crt="Network problem"; break;
    case "sd/334f5c8f-ab42-4c27-aaed-aec34dbd8fa8": crt="Mail issues"; break;
    case "sd/5486c448-1848-467f-bd6a-7bcab790a0d4": crt="Missing or lost hardware"; break;
    case "sd/68b098b2-9634-4bb6-b7cf-ca0a85e2e015": crt="Unlock account"; break;
    case "sd/a97e5bce-feaa-4b77-96f4-43648c9c1528": crt="Reset password"; break;
    case "sd/068b93a6-02f0-47d7-8e1f-883eb78bd220": crt="Report unauthorized access to IT systems"; break;
    case "sd/14156341-2fee-445f-ab8a-f21f3e66c55b": crt="Extend disk space"; break;
    case "sd/d0c0d8f8-6e6a-4774-a386-400aed2ef8ba": crt="Wipe mobile device"; break;
    case "sd/e674cc7a-e556-40fb-9221-d6a21db240b6": crt="Other issue"; break;
    case "sd/69b7b23e-abf8-48e8-8c2c-7777d58edee0": crt="Other request"; break;
    case "sd/e4ae846c-0c8c-4e5a-a423-fe00ee31bd0b": crt="File Share issue"; break;
if(customerRequestTypeValue=="sd/c0e84f82-b0fa-4455-a35b-459a4482008a" && customerRequestTypeValue=="sd/ffcd2750-6df1-4dad-a6b4-d97375dac5f0"  && customerRequestTypeValue=="sd/69293647-7944-470b-b2ee-c02643560a51"  ){
    setSummary(issue.getKey(),issue.getSummary()+ " " + crt);
}else{
    setSummary(issue.getKey(),crt + ": " + issue.getSummary());
return true;
Nothing obvious jumps out at me, except all the String comparisons in the case statements.
I'd start simple and see how that runs. For example, how long does a script take that just calls setSummary with a fixed string. Then add more code. Perhaps use a StringBuilder class instead of concatenating Strings? In the end, some judicious println may show you the time of each part.
