Single Project Automation doesn't make edits to Issues in another project
Alex Hall
I'm working on some cross project automations.
When new issue is created in Project A:
  • Check for text, if it matches, create new issue in Project B
  • Close Project A
  • Write a comment on the ticket in Project A and in Project B
However, the comment on Project B doesn't get written unless the rule includes Project B in the scope. But if I include Project B in the scope, then the rule runs for both Project A & Project B every time a new issue is created.
A similar problem for manually triggered rules
  • When triggered in Project A, it creates issues in Project B (and C and D).
  • If the Scope is expanded to include Project B, C, & D, then end users can see the rules which are designed to be triggered in their projects.
  • But if the Scope isn't expanded, then actions in branches of "For: All created issues" or "For: Most Recently Created Issue" don't get executed.
  • Actions when the Issues are created always execute, but you can't add a comment when creating a new issue.
Has the community dealt with this? Any suggestions to work arounds?
Bill Sheboy
February 28, 2024
Hi @Alex Hall
To make such multiple-project (or global) scope rules work as expected, please try using conditions to limit the processing.
For example, in your scenario:
  • when issue created in Project A,
  • look for matching issue in Project B, and when found
    • close the issue in Project A
    • add a comment to the issue in Project B
Adding a condition immediately after the trigger to check if the {{issue.project.name}} matches what you expected.  That will prevent issues created in Project B from allowing the rule to proceed.
And as a precaution to rules triggered on Issue Created, I recommend always adding a Re-fetch Issue action immediately after that specific trigger, and before any conditions / other steps.  That trigger can fire so quickly that some issue data may not yet be available.  As a result, conditions and other rule steps may not work as expected.
Alex Hall
Thanks. I'll try the re-fetch to see if that works. The other solution, while it sounds like it would work, sounds overly complicated when I consider how many rules would have to be created.
Alex Hall
The re-fetch did work. Adding the re-fetch before any desired comment additions allowed for the comments to be created regardless of which project the created issues were in.
