Smart Value .urlEncode Not Working in Jira Automation Web Request
Sairam Adla May 2, 2025
I'm trying to use Jira Automation to construct a dynamic URL for accessing the public Azure Retail Prices API:
dynamic URL with OS smart value with url encode
Expected Resolve-URL
However, the resolved URL ends up with an empty value for ProductName:
resolved URL
It seems like .URL Encode is either not being applied or causing the smart value to fail silently. I’ve verified that the OS field has a value before encoding.
Could someone from the community or Atlassian confirm:
  • Whether .URL Encode is fully supported in Jira Automation for web request URLs?
  • If not, is there a workaround or recommended pattern to safely encode smart values with spaces or special characters in URLs?
Thanks in advance for the help!
Bill Sheboy
May 2, 2025
Hi @Sairam Adla -- Welcome to the Atlassian Community!
In my experience, the Send Web Request action can have timing / racetrack problems where the URL, request message, etc. might not fully evaluate fast enough when they contain smart values before they are validated and used.
I recommend trying this to diagnose and mitigate timing problems:
  • use the Create Variable action to first create the URL and request, perhaps named varURL and varRequestMessage
  • echo those to the audit log using the Log action
  • then use them in the Send Web Request action as {{varURL}} and {{varRequestMessage}}
  • when testing, carefully review the log for any unexpected values
Florian Bonniec
Hi @Sairam Adla
What is the smart value you are using ? What is the expected vs actual result ?
Regards
Hello @Florian Bonniec
Sure! I've updated the description—please take a look.
Thank you!"
Florian Bonniec
Do you have a screenshot of the automation action ?
@Florian Bonniec  Yes
Florian Bonniec
The web request action seems to worked well, the issue is when you try to add probably the response as comment to the issue no ?
@Florian Bonniec
no, resolved url ends up with empty productName(OS),
not able to use smart value with urlEncode
, even web request action is succeed no use Resolved url with empty productName(OS)
Florian Bonniec
Based on the screenshot you apply .urlencode to OS only not Region nor VM SKU
@Florian Bonniec , yes I applied for OS but it not working
Florian Bonniec
based on teh screenshot you provided you send {{Region}} not {{Region.urlEncode}}
