Smart value {{issue.issuetype.name}} doesn't return any value
Pauline Dupuy February 16, 2023
Hello there,
First and foremost, i'd like to thank this community that allow me to find every answer i was looking for so far.
HOWEVER, i'm stumbling on a stupid problem.
I'm trying to use the smart value {{issue.issuetype.name}} in my automation, so the email that is sent shows the issue type name in my list of task along with summary, key etc..
My automation is as follows :
Trigger : scheduled every monday at 9am
 1. Lookup issues
 2. Send email (content below):
{{#lookupIssues}}
<a href="{{url}}">{{key}}</a> - {{summary}} - {{issue.issuetype.name}}
Everything works fine BUT no value from the smart value {{issue.issuetype.name}} is returning in the email, it's just blank.
The type of issues are not custom.
I really don't understand what is wrong.
Thanks !
4 votes
Walter Buggenhout
Hi @Pauline Dupuy and welcome to the Community!
I am not sure if these smart value keys are case sensitive, but I would not be surprised if this does matter. From the documentation, issueType has a capital letter 'T':
{{issue.issueType.name}}
Hope this helps!
Thanks for your reply Walter, i already tried that, and it's not case sensitive :)
Walter Buggenhout
Have you tried to just leave out the initial issue part? I notice that it is not being used for key and summary either. So:
{{issueType.name}}
Like # people like this
Pauline Dupuy February 17, 2023
Yes that's it.
I had already tried this but without the capital T !
So both your answers are good in the end
Thanks a lot, you saved my day.
Tobias H
February 16, 2023
I believe it is as @Walter Buggenhout wrote in his latest reply, drop the issue before issueType and it should work.
I have a scheduled automation in place to post new additions (last 24h) from our backlog to our teams Slack channel and in it I use an almost identical code as what you wrote in the initial question.
{{#lookupIssues}}
<{{url}}|{{key}} - {{Summary}}> [{{issueType.Name}}]
Tobias H
February 16, 2023
Comes out looking like this:
(If you copy my code, feel free to drop the brackets around the issueType if you don't like how it looks. And perhaps move the > behind summary to behind key instead, if you don't wish for the summary to be clickable.)
I've made this change yes after Walter's answer and it works fine. Thanks
Have a nice day
Like Tobias H likes this
