Smart value to get the issues links in issue?
Angel Ferreira
I want to send a notification with the issues links related to an other issue but I couldn´t found the smart value for that.
Thanks for your help
Bill Sheboy
December 10, 2022
Hi @Angel Ferreira
Please try {{issue.issueLinks}} to do that.
Perhaps if you explain your use case a bit more the community can provide more suggestions, as I suspect that you may want to send this list in one notification (e.g. email), and so perhaps bulk processing from a branch would help: https://confluence.atlassian.com/automation/run-a-rule-against-issues-in-bulk-993924653.html
Angel Ferreira
Hi @Bill Sheboy
Thanks but I need the list of issues links relate to a one issue. For example I´ve an issue with key "Test-1" and this issue have other 3 linked issues "Test-2", "Test-3", "Test-4" so in my email notification I need something like that
 __________________________________________
                          Issue Data
Main issue: Test-1 #{{issue.key}}
Linked issues: Test-2, Test-3, Test4 #{{issue.issueLinks}} without links only data
I tried with the smart value that you shared with me but it doesnt work
Bill Sheboy
December 13, 2022
Automation rules often take a bit of experimentation and a bit of learning, reviewing the documentation to learn what is possible: https://confluence.atlassian.com/automation/smart-values-in-jira-automation-993924627.html
I gave you the starting point for the links.  To get just a list of the keys to the linked issues from the trigger issue, please try:
{{#issue.issueLinks}}{{.}}{{^last}}, {{/}}{{/}}
Angel Ferreira
The same result ,I tried with differents options from documentation but I get the same result like image that I shared
Bill Sheboy
December 13, 2022
I am using Jira Cloud, and not Server/Data Center version...and it would appear the smart values may be different for issue links between those two...although that seems surprising to me.
Let's try this...
Please post images of your complete automation rule and the audit log details showing the rule execution.  Those may help explain what you are observing.
Next, please use the steps in this how-to article to confirm the correct smart values for what you need: https://confluence.atlassian.com/automation/find-the-smart-value-for-a-field-993924665.html
Like # people like this
Angel Ferreira
Thats was helpful, the expresion that I need was:
{{#issue.issueLinks.inwardIssue}}{{.}}{{^last}}, {{/}}{{/}}
Like Azfar Masut likes this
