×Hi,
I have performed a synchronization between 2 projects in Jira. Everything is fine until it's time to edit or delete comments. I can only delete or edit the last comment, as I have no way to get the id of a specific comment. Any ideas on how to get that id out of a specific comment?
Than you.
Can you elaborate a bit more?
Are you using REST APIs or automation?
if you are using REST APIs what are the end points that you have used
Can you share the automation rule that you have so far?
if you use advanced branching, you should be able to loop through all comments. But would be good to see your rule built so far
