Hi Dear All,
My question is something about jira automation. Is there a way of synchronizing the comments for linked (escalated) issues in jira automation? For example, I want to see any comments posted on escalated issues in same project.
Actually all I want is to see same comments in escalated issues
which Plugin are you using for automation?
I am not actually using plugin for it. It is just Jira Integrated automation (Project Name -> Project Settings -> Automation)
I see, it might be service desk project . correct me if i'm wrong.
where exactly you want to see the comments posted on escalated issues, is it through mail then you need to write automation rule
You are right it is service desk project on cloud
I want to see that comments in escalator issue if a comment posted for escalated issue or vice versa. So, it is like you comment an issue then it will be commented for linked issues, too.
Go to automation, click on add rule > select custom rule > write below rule
I don't find copying the comment field value to linked issue, you have to use some plugin for that to achieve, suggest me if you find another way of doing it
