There was a problem restoring ActiveObjects data for the <unknown plugin> plugin
Rob B
August 1, 2019
Im trying to restore to our DEV environment from a backup took from our PROD, but gettin an error at the end of the restore.
Error:
There was a problem restoring ActiveObjects data for the <unknown plugin> plugin. Caught exception with following message: ORA-02298: cannot validate (JIRA.fk_ao_54307e_slaaud708664691) - parent keys not found . Please check the log for details.
Jira v 7.13.1
Alexey Matveev
August 1, 2019
Find all objects with ao_54307e and delete them.
You can find more info here:
https://community.atlassian.com/t5/Jira-articles/How-to-clean-irrelative-ActiveObjects-data-in-Jira-backup/ba-p/875608
Rob B
August 1, 2019
Hi Alexey thanks for your quick reply,
So they only way to fix it is to amend the xml?
Thanks Rob
Alexey Matveev
August 1, 2019
I believe so
