we're using Service desk project called SUPPORT and create linked issues to an Jira Software project called APP if a issue is confirmed. The linked issue is linked with "is caused by".
After closing the linked APP issue, there is a comment in the SUPPORT issue (see screenshot)
I
I've checked workflow post functions from open to close (see below)
We've a second identically workflow step from reopened to close (see below) but in this step theres no comment added.
Is there any built-in feature in Jira where comments are added to linked issues?
Thank you!
Best regards
André
I solved this issue.
Jira Service Desk has a build-in feature for automation tasks. After install, there is a task which will add a comment to Service Desk Issues if a "caused by" issue is closed.
Go to: project configuration -> Automation
Hello @Andre Schäfer
There are no builtin functions for that.
It seems that comment added with Scriptrunner Postfunction, try to check code,
Hi @Mark Markov
thank you for your reply. I've checked Scriptrunner postfunction code. Theres only this code inside
This code does not add the comment to linked issues I think.
