We created an automation using Jira Automation that has the following settings:
1. When: Issue created.
2. If Reporter = x
3. Then: Send email
to: Reporter
subject - a new issue was created and is awaiting your response
Content:
The issue: <a href="https://jira-address/browse/{{issue.key}}">{{issue.key}}</a> was created and it is waiting your action.
Please approve or reject this request:
<br>
<a href="https://jira-address/secure/WorkflowUIDispatcher.jspa?id=392248&action=731">Approve"
<br>
<a href="https://jira-address/secure/WorkflowUIDispatcher.jspa?id=392248&action=732">Reject"
This does not work and we get "Encountered a "403 - Forbidden"
error while loading this page. Go to Jira home" , probably because the actual link behind the issue transition includes a token:
But this token changes at each log in. Is there a better solution using jira automation? Either to dinamically get the token, or some other method.
Thank you!
Hi Mihai!
There is a somewhat "hacky" solution to this that could work for you.
In your Send email action you just need to specify the link with a smart value fetching the correct issue ID.
Step 1
Create a test issue and make sure it is in the status where the Approve/Reject transitions are available. In my test issue it needs to be in Pending Approval. From there my options are Approve and Reject.
Step 2
Right click on the relevant transition button and choose Copy link, I'll choose Approve as an example. My link is: https://MY-JIRA-DOMAIN/secure/WorkflowUIDispatcher.jspa?id=1015540&action=31&atl_token=BWU5-ZFEP-ZCCQ-MQQZ_61d35342348b104b2416708039e71a51547b8d59_lin
Step 3
Paste this link where you want it in your email body from the Send email action and replace the first parameter (id) with a smart link for the issue ID:
https://MY-JIRA-DOMAIN/secure/WorkflowUIDispatcher.jspa?id={{issue.id}}&action=31&atl_token=BWU5-ZFEP-ZCCQ-MQQZ_61d35342348b104b2416708039e71a51547b8d59_lin
If the user clicking the link isn't logged in s/he will need to do so, and then be met with an alert saying that the XSRF security token is missing.
It's just a matter of clicking Retry Operation and it works, but it is the clunky part of this hack :)
Hope it helps!
Hello Robin,
Thank you for your reply!
This works, but only until I log out and log back in again. The token: "&atl_token=BWU5-ZFEP-ZCCQ-MQQZ_61d35342348b104b2416708039e71a51547b8d59_lin" changes at each log in, so, probably, it is per user & per log in.
I'm not sure if there are other options besides this.
Thank you.
Hi there,
Thanks so much for your feedback!
I’ve linked your suggestion to a related feature request, which counts as an upvote for this ticket:
https://codebarrel.atlassian.net/browse/AUT-275
Charlie
