Trigger automation by issue types change is not working for me
Sia (Nastassia) Sharasheuskaya January 13, 2025
Hello all, I have tried a lot to fix this trigger but it is just not catching issue type changes within the same project.
Here is what I tried:
1. Trigger:
{{issue.changelog.isssuetype.fromString}} equals Bug
and then {{issue.changelog.isssuetype.toString}} equals Release Blocker
so all together:
2. I have also tried:
{{fieldChange.fromString}}
{{fieldChange.toString}}
3. I have also tried using the Issue Moved trigger with a follow-up check on the new issue type
4. And also tried using the Field change trigger without smart values and just using the final issue type value to check against like in the attempt above (#3)
Nothing works. Can anyone help? I need to track the following issue type changes:
Bug to Release Blocker
Bug to Incident
Release Blocker to Incident
Incident to Bug
Release Blocker to Bug
They are all in the same project
Rilwan Ahmed
Hi @Sia (Nastassia) Sharasheuskaya ,
You need two IF conditions. For Bug to Release Blocker
1. Add smart value condition as below
{{#changelog.issuetype}}{{fromString}} {{/}}
Condition: Contains regular expression
Regular expression:  Bug
2. Issue matches JQL.
Type = 'Release Blocker'
Your rule will look as below. Here the rule will add comment when issue type changed from Task to Epic.
Thanks this now works!!!
Stephen.Lugton
It looks like you've spelled issuetype wrong in both your IF statements
John Funk
Hi @Sia,
Can you share the audit log for when you run it? That way we can tell what is getting processed.
This is the only thing in logs, no errors
