Update a checkbox through Automation for Jira
Antoine _Klee Group_
February 17, 2022
Hello, I want to write a script that updates a checkbox field without overwriting previously entered values.
Using the "edit issue" in such a way overwrites previous values.
Pretty sure I need to use the "advanced field edition" using the Json format and the "update" key but I find no accurate documentation about it.
Anyone to help?
Bill Sheboy
February 17, 2022
Hi @Antoine _Klee Group_
Please take a look at this documentation page: https://support.atlassian.com/cloud-automation/docs/advanced-field-editing-using-json/#Multi-select-custom-field
To add to a multi-select option field, you would want to use "update" and "add", rather than just the shortcut version with "fields".
Another option is to capture the existing values in a created variable and re-add the values with the new ones in one single edit.
February 20, 2022
Alright thanks for the reply @Bill Sheboy
Like Bill Sheboy likes this
