In Jira, to manage the allowlist (also known as the whitelist) for allowed URLs, you generally follow a similar process to what you see in Confluence. However, the exact path may vary slightly based on the version of Jira you are using. Here are the typical steps to add URLs to the allowlist in Jira:
1. Log in to your Jira instance as an administrator.
2. Go to the **Administration** panel. This is usually accessible via the gear icon in the top right corner.
3. Navigate to **System**.
4. Under **Security**, look for **Whitelisting** or **Allowlist** (the exact name can vary).
5. Here you can add, edit, or manage the URLs you want to allow.
Since the navigation structure can vary slightly depending on the version of Jira you are using, here is a more generic step-by-step guide:
1. **Log in as Admin**: Ensure you are logged in with administrative privileges.
2. **Access Admin Settings**: Click on the gear icon (⚙️) usually located in the top right corner.
3. **System Settings**: In the left-hand sidebar, look for the **System** section.
4. **Security Settings**: Under the System section, find **Security** and then look for **Whitelist** or **Allowlist** settings.
5. **Manage Allowlist**: Here you can add the URLs or patterns you want to allow.
please provide a Step?
i am using a Jira API in angular application and how to Whitelisting or Allowlist for CORS issue fix? please suggest me how to CORS Issue fix.
There is no API option on the Atlassian admin side to add whitelist/allo list options.
how to use JIRA API in angular application any solution? how to fix CORS issue any idea?
Hi @Marc - Devoteam. Is there still no way to change the whitelist via REST API? If it's still not possible, could you please tell me when you plan to add this feature?
@Mikael Sandberg @Rilwan Ahmed @Trudy Claspill @Jack Brickey @Nikola Perisic Could someone help me with my previous question please?
Adding a related question to a post that is more than 6 months old is considered "necroposting" and is discouraged per the Community Guidelines.
I recommend that you start a new Question by clicking on the +Ask a question button at the top of the Forums screen. Describe your complete scenario. If this current post is relevant than add a comment about that and a link to this post.
The other reason to start a new question is because only the people that replied to this current question, the original author, and people Watching this question are notified of changes to it. Creating a new Question will result in your question moving to the top of the unanswered questions list, which will make it visible to the wider community and more likely to get input from more community members.
Also note that we are a user community, not (necessarily) employees of Atlassian. We don't usually have any special insights into when Atlassian plans to add features. You can review the Cloud Roadmap that they make public for that sort of information.
https://www.atlassian.com/roadmap/cloud
You can also search for change requests in their public backlog.
@Trudy Claspill Ok, I already created the new ticket here https://community.atlassian.com/forums/Jira-questions/Using-a-JIRA-Rest-API-add-setting-Allowlist-in-JIRA-Admin-Panel/qaq-p/3106493#M1147285 , thanks for responding
