Using a Nunjuck script in a POST function to change a custom field value
David B
I am trying to modify a work flow to set the Request Type to a specific type on creation of a new work item based on a value that gets passed from the trigger issue :
{% if (issue.fields["QA Score"] | default(0)) < 100 and (issue.fields["QA Score"] | default(0)) > 89 %}
{{issue.fields["Request Type"].requestType.name}} = "QA: Minor"
{% endif %}
That's what I am trying to use and maybe there is a better way to do this and would love some input on this.
John Funk
Hi David,
Are you using JMWE? Is there a reason you are trying to use a Post Function instead of an Automation rule?
David B
If you are referring to Automation in Jira, I want to try and avoid using that because I do not know how many times it would run in a month and I do not want to burn through our monthly allotment.
We are using JMWE but it did not seem to be working for some reason, turns out the reason was me. I had to change the Run As setting on the JMWE rule and it worked fine.
Also thanks for the reply John!
Like John Funk likes this
John Funk
Great! Glad to hear you got it working!
Like David B likes this
Oleksii Melnyk
August 16, 2025
Hi @David B
I think you can use Jira Automation.
Just use Work item fields condition.
Select QA Score less then 100 change request type (via JSON edit) to QA: Minor.
David B
Oleksii - I am a little confused by what you mean but it turns out I was able to do it with JMWE once I resolved my own user error :) Thank you for the reply.
