Values from Custom Field not appearing in Confluence Table Filter
Robbie Wareham April 1, 2019
I have created 3 custom field types via a bespoke plugin, all of which appear to work in JIRA.
However, when I use the Table Filter macro in Confluence to retrieve issues from Jira including instances of the custom field types, the column names appear, but all data is empty.  When the query is run in Jira, the issues returned all display values in these fields.
Interestingly, I have some other fields which are scripted using the Adaptavist plugin, and these are correctly displayed in the Table Filter.
I am implementing "edit" and "view" velocity templates, do I need to implement an XML resource too?
To confirm, I am using Server rather than Cloud
Robbie
Andrey Khaneev _StiltSoft_
April 1, 2019
Hello Robbie,
Yes, you need to implement an XML template. XML template is used to export issue field values to Jira Issues macro and some other places.
April 1, 2019
XML template should look like this:
<customfieldvalue>
$value
</customfieldvalue>
Ah, I added that to my view template, as I saw post where people were talking about customfieldvalue and assume it was HTML
LOL
Just to confirm, I don't need this in the view template as well?
April 1, 2019
No, customfieldvalue is needed for XML only.
KMuthukumar-RP July 21, 2020
@Andrey Khaneev _StiltSoft_ @Robbie Wareham I am facing the same issue. Can you please elaborate little bit on which template you guys are talking about, where this is and what do I need to set?? Thank you
August 15, 2020
Hi @KMuthukumar-RP,
What issue do you experience? In the case above a custom field was created using Adaptavist plugin, but the definition was not complete and the field could not be exported through Jira Issues macro.
Did you create the field by using some kind of programming, or is it a custom field of type available in Jira by default?
Uday Joshi
I'm facing the same issue. Some of the JIRA custom fields don't get displayed immediately on the confluence dashboard created using a Jira filter.
Can someone help please?
Nabeel Ahmed
August 14, 2020
Hello, I'm receiving the same issue on version 7.6.1. A custom field from jira is not being populated in a table created in confluence. Any guidance on how to solve this issue.
Thank You.
August 15, 2020
Hello @Nabeel Ahmed
Did you create the field by using some kind of programming (like in the initial question), or is it a custom field of a type available in Jira by default?
Jira LBProAdmin August 21, 2020
I have the same problem,
I created the custom field by default Jira option.
Oriyah Barzilay
@Jira LBProAdmin did you figure this out?
