When I add a custom field on Jira issue View screen only, that field is not visible on issue view
Rompicherla Kalyani
When I add a custom field on Jira issue View screen only, that field is not visible on issue view.
When I add the same field on Edit screen, then only its getting visible on ticket view.
But I need to make the field Readonly, hence I dont wanna configure on Edit screen.
This is for Jira Software Company Managed project.
Can someone throw some light here please.
Thanks.
Pasam Venkateshwarrao
May 14, 2024
Hi @Rompicherla Kalyani
I want to understand whether you have used same screen for create/view/edit screen?
Kai Becker
did you configure the issue layout and show the field on the context area?
A detailed guide can be found here: https://support.atlassian.com/jira-software-cloud/docs/configure-field-layout-in-the-issue-view/
Kai Becker
@Rompicherla Kalyani did you check the layout as mentioned?
Bo Zhao
May 13, 2024
Have you associated the custom field with the View Only screen yet? I would recommend checking the field association to see where the new field gets displayed.
You can check the "Associating a custom field with an issue screen" session from the guide here - https://confluence.atlassian.com/adminjiraserver/adding-custom-fields-1047552713.html
Rompicherla Kalyani
Hi @Bo Zhao
Thanks for the response.
I've already associated the concerned field to view screen.
Its still the same though.
Thanks.
