Dear community please help to find realy working solution to integrate two factor with jira server.
Im loking maybe some solution how to use google authenticator which we trust.
Can it be configured? Or only one way to use 3rd party addons?
Can somebody describe your experience?
Hi @Yuriy Tsymbaliyk ,
There are several add-ons that proved 2FA feature on marketplace. I evaluated the following one before.
Regards
Yes, i find them, did you use them? or try to configure?
Can you describe your expirience?
Yes, I used it before without any problem. You can look at add-on's documentation for further information. Hope it helps.
Yes it worked correct, even on VM.
I install it on VM and it start work.
Can you describe how users work with 2FA?
Did you get some issue with API?
Issue with jira-confluence directory sync?
Hello there,
I hope all is well on your end.
There multiple 2FA plugins available for on the Atlassian Marketplace which supports 2FA for Jira.
Here is one of the Atlassian's Top Vendor plugins that use Google Authentication to support 2FA for Jira.
https://marketplace.atlassian.com/apps/1221260/two-factor-authentication-2fa-for-jira?hosting=server&tab=overview
The plugin also provides the Security Question as a Backup method or as an emergency method. So, if the user doesn't have access to his phone, he can use it to get access to Jira.
Also, it would be better if you can raise a support ticket to the vendor for faster resolution.
Again, if you are using the miniOrange, you can raise a ticket from the link given below. They will help you out to configure the plugin.
miniOrange Support
https://miniorange.atlassian.net/servicedesk/customer/portal/2
Vikas
