For project creation we need the to create our own project templates or use existing projects as templates. There is also already a feature request for this, untouched by your side since 2014: https://jira.atlassian.com/browse/JRACLOUD-40141
Is there a workaround for this unknown to us?
There should be an option to "Share settings with an existing project" on creation in cloud which pretty much achieves this goal... the only problem is that having shared settings has other impacts - namely changing one changes all... this might be what you want, but if not its a problem.
Thank you for your answer. You are referring to the UI. I was referring to the API.
Can you help us there?
Hi Julia - apologies I missed that reference. I haven't seen anything in the standard API for this on the cloud. I have used Config manager in the past for this.. but its server only. I would recommend taking a look at the CLI app on the marketplace which may be able to help on cloud?
