email creates issue then sender sends same email again and a duplicated issue is created
Ghazanfar February 2, 2018
One of the employees sends email to helpdesk@dadadada.com
Problem 1. She uses only 3 subject lines for all the issues (+200 issues and all of them have the same subject text.
Problem 2. She sometimes duplicates the same issue after a few hours in a different email and again uses the 3 special subject lines so issue 1 gets registered with subject line "A" and after few hours the same issue 1 gets registered with subject line "B" and a day later, the same issue is reported with Subject line "C".
Does anybody have a miracle or a magic pill?
Thank You very much even just for looking at the situation.
Kind Regards.
Alexey Matveev
February 2, 2018
How did you setup your email handler? Does it always creates issues or also create comments?
When a responsible person handles it, everything works just fine. new replies go to comments etc.
Alexey Matveev
February 2, 2018
Issues go to comments only if there is an issue key in summary. If not then a new issue will be created. If you want to change the behaviour you could use plugins.
Let me state the situation a bit more clearly because I forgot to mention this in the Question.
There's always a unique identifier number anywhere within the body/content of the email (e.g. this is a problem, record of customer # 12345 needs manual update).
I have been using JIRA for 4 days. Just 5 days ago I didn't even know it existed. I am more a networking/windows administration guy but now a company has asked me to see it and improve the workflow for which I seriously have no clue for now.
Thank You Very Much for Taking Interest and Thank You for Your Time Alexey Matveev.
Alexey Matveev
February 2, 2018
Jira can not parse a email body out of the box. You would need an add-on for it. For example, Email This Issue. You can find more info here:
https://marketplace.atlassian.com/plugins/com.metainf.jira.plugin.emailissue/cloud/overview
With this plugin you could parse mail and not to create a new issue if an issue with #12345 exists.
There are also other add-ons available. Or you could took Power Scripts add-on and write your own mail handler. You can find more info here:
https://confluence.cprime.io/display/JJUPIN/Mail+Handler
Ghazanfar February 5, 2018
Thank You Alexey Matveev
