Hello
I have created a global rule in the automation module.
When a user story is created it should look at the parent epic (this can be an Epic from another project) if the value of the field <<reporter>> is equal to XXXX
then set the value of the field yyyy within the user story to zzzz
But the rule does not work what am i doing wrong.
This could be a timing issue with the Issue Created trigger, where all of the data is not yet available at the moment the rule executes (e.g. the trigger issue's epic info). Please try adding a Re-fectch action immediately after the trigger. That will slow down the rule and re-load the data before trying the condition.
Hello @Eric Roetenberg
Can you confirm that the issue in the Audit Log for the rule has a parent Epic where the reporter on that Epic matches the user you have specified in the rule?
Can you tell us whether the project specified for the issue in the Audit Log is a Team Managed project or a Company Managed project? It would say which it is at the bottom of the navigation pane on the left when you are viewing that project.
