Hi Beatriz,
you can add Fix Version/s to your boards (Card layout).
Fix version is the version where you plan on releasing a feature or bugfix to customers. This field is used for release planning, monitoring progress and velocity, and is used widely in reporting.
From the excellent Atlassian Agile Coach:
in Jira Software, versions (or a Release) represent points-in-time for a project. They help you organize your work by giving you milestones to aim for.
Hi @Beatriz Aparecida Feliciano
Here is some relevant info that can help you: https://confluence.atlassian.com/adminjiracloud/managing-versions-776636296.html
Hope this helps!
I' d like to know how to place pending or ongoing items in this area
@Beatriz Aparecida Feliciano To do, In progress, Done, items will show in that view once you start adding issues to a specific version. IE:
And here is the link to customize the cards: https://confluence.atlassian.com/jirasoftwarecloud/customizing-cards-764478020.html
Hope this helps!
