I use the lookup function to send a summary email to my colleagues with a list of their problems.
It works but my email is sent several times. I think it's because of the jql filter in the trigger which executes the rule for each ticket found
If I uncheck "Run a JQL search and execute actions for each issue in the query." , I cannot save my automation rule. I get a message "The rule has been configured with components that require issues to be provided by the trigger. You need to use the option to run JQL to provide issues. The following components require issues: Comment on issue"
Is it possible to run a scheduled automation without a JQL filter?
Is there a setting to modify somewhere?
If your goal is to only send an email with a list of issues, I would first look into creating a filter subscription as that would be the simplest approach.
If you still want to go the route of automation, you can execute without JQL, but you'll need to use the Lookup Issues action to get the list of issues.
From there, you would update the body of your email to something like this:
{{#lookupIssues}}
{{key}} - {{summary}}
This will ensure that only one email is sent.
Note - If your goal is to have individualized summary emails sent to each recipient, there will be a little more complexity added to the rule. If that's your end goal, you could perform advanced branching. Here's a thread that speaks to that:
Thank you for this quick response
I actually did automation with Lookups Issues action and branch
but my problem is being able to uncheck the JQL filter in my trigger. This is what I cannot do.
So the challenge here is that you're branching on a variable rather than specific issues and the problem is with the comment which doesn't have a point of reference against that advanced branch. You'll need to consider a separate JQL-based branch for the comment.
I agree, the comment is poorly positioned
but that is not the subject of my request.
as it currently stands, the rule sends me several identical emails. I would like to have a single email per assignee.
I suppose it's because of the JQL search in the trigger but it's impossible for me to uncheck it
Can you please share a screenshot of your send email rule? Also - I think you need to use the variable {{mailTo}} as your Send Email recipient instead of assignee.
Thank you - So there are two issues:
{{lookupIssues.assignee.distinct}}
{{mailTo.emailAddress}}
Thank you for your help.
I succeeded by correcting some errors in my automation thanks to your suggestions
I also found similar automation here:
regards,
That error is indicating there are rule components trying to use a current issue, but one is not in scope. And so the error is trying to "help" by suggesting adding JQL to the trigger, which is wrong for your scenario.
Please look for anything in your rule using {{issue.some field}} where some field is an issue field. That usage should probably refer to the lookup issues you referenced.
