is there a way to select a string between a string and new line?
Rajeev Chaudhary February 24, 2022
I am trying to use automation and want to place a value from the description to a custom field.
Eg Description contains -
Brush Size: 2
Paint: Blue 2291 54
Wall#: 34
i have a custom field called Paint and to map the value to that field, i am using the following:
{{issue.description.substringBetween("Paint: ","Wall#: ")}}
its returning: Blue 2291 54{color} {color:#172B4D} as its reading the color of the new line between 1st row of "Paint: " & "Wall#: "
Is it possible to use between function for capturing strings between a string and a new line?
thanks in anticipation
5 votes
Bill Sheboy
February 24, 2022
Hi @Rajeev Chaudhary -- Welcome to the Atlassian Community!
Yes, that is possible.  Try to split the description on the newline character first, producing a list of lines. That will simplify your search using a regular expression with the match() function.  For example:
{{issue.description.split("\n").match("Paint:(.*)").trim()}}
Please adjust as needed if you need to remove/add any spacing.
Rajeev Chaudhary February 28, 2022
thank you so much!
Like Bill Sheboy likes this
Rabbit Stoddard
This also solved a problem I was having; thank you very much!
