I'd like to do the following:
But how do you assign a converted sub-task under a task?
Hi @Gavin
Assuming you're using the Edit Issue Action to change the issue type, you'll need to include the parent field as part of the edit. If you're not able to select it from the available fields, you'll want to do it via json like this:
"fields": {
"parent": "PARENTKEY OR SMART VALUE"
Thanks for the response.
Unfortunately the didn't work. in the audit log I got " Error while parsing additional fields. Not valid JSON." What kinda of worked was
> edit issue
+ linked issue > is subtask of <parent>
"fields": {
"parent": "MDM-1920"
"environment": "Thanks for raising {{issue.key}}.",
"labels": [
"bugfix",
"blitz_test"
"Custom Field Name": {
"value": "red"
Hi @Gavin - Let's take a step back on this one. I don't think this one should require JSON. Can you please share a screenshot of your rule?
So I was looking at the errors and it states "(Issue type is a sub-task but parent issue key or id not specified. (issuetype))" which was what you mentioned above but not seeing where I can put the parent ID.
Just above where you selected Sub-Task as the issue type, there's a drop-down "Choose Fields to Set" where you can set the desired fields you wish to edit as part of it.
Note - That warning message is critical. If your Task and Sub-Task have different workflows, this is going to fail. The only way that you can use automation to convert one issue type to another is if they share the same workflow. Otherwise, this would be a "Move" operation which is only possible through a manual function on the Jira UI
thanks for the response. Hmm I'm looking at it there
I'm not seeing where I can set the parent ID.
Makes sense that parent isn't there because you're currently editing an issue type to change into a sub-task. I would just take the following action:
"fields": {
Lastly, is the expectation that every action item will become a child of MDM-1920 for perpetuity, or just this one situation? If the former, you're all set. If the latter, you'll need some type of business logic to help define what parent it should be linked to.
"fields": {
"labels": [
"bugfix",
"blitz_test"
"value": "red"
