post request with headers in scriptrunner
Oleksiy Ohmush June 5, 2019
Hello
I`m trying to use scriptrunner to reset cache in cloudflare.
I have api key, zone id, login in customfields in issue.
customfields : api, zone, login
def http = new HTTPBuilder('https://api.cloudflare.com/client/v4/zones/$zone/purge_cache')
http.request(POST) {
requestContentType = ContentType.JSON
body = [{"purge_everything":true}]
response.success = { resp, JSON ->
return JSON
How to add headers and what libs should I import?
Oleksiy Ohmush June 6, 2019
Actually i find a solution. Problem was in invalid URL
def http = new HTTPBuilder('https://api.cloudflare.com/client/v4/zones/'+zone+'/purge_cache')
http.request(Method.POST) {
headers."X-Auth-Email" = "$mlogin"
headers."X-Auth-Key" = "$api"
body = '{"purge_everything":true}'
Stefano Coletta October 20, 2023
Is there a way to set these headers in the HTTPBuilder object?
In my code I have to do multiple requests and I would like to set them only at the beginning.
PD Sheehan
June 5, 2019
Try something like this (2 variants proposed)
No additional import required, it's all part of HTTPBuilder
def headerKey= "something"
def headerValue = "somethingElse"
headers."keyForYourHeader" = "value for your header"
headers[headerKey] = headerValue
    return JSON
Thanks for reply!
I tried, but i guess i do something wrong
And it contain error if i try to use {} in body
Снимок экрана 2019-06-05 в 23.37.08.pngСнимок экрана 2019-06-05 в 23.36.54.png
PD Sheehan
June 5, 2019
If you want to store the header key in a variable, you must assign it to the headers object using the square bracket format.
When you do headers.headerKey, you are trying to create a header with the literal key of "headerKey"
So try:
headers[headerKey] = mlogin
(or is mlogin the literal value for the header? in this case, include it with quotes: "mlogin")
But more simply, to set the two headers you showed in the screenshot, there is no need to first declare them as variables, just include:
headers."X-Auth-Email" = "mlogin"
headers."X-Auth-Key" = "api"
I tried, guess i still need to include some libs
body = ["purge_everything":true]
return JSON}
No such property: POST for class: Script696
PD Sheehan
June 5, 2019
I was assuming you already had the HTTPBuilder imports... and I only used the code you posted.
These are what I use:
import groovyx.net.http.ContentType
import groovyx.net.http.HTTPBuilder
import groovyx.net.http.Method
 Then you request is done with
http.request(Method.POST) {...}
Like Oleksiy Ohmush likes this
Thanks, now POST method works but still bad requestСнимок экрана 2019-06-06 в 08.34.58.png
