some resource are not using https scheme
Cheng Qiu November 25, 2017
I configured jira after apache server with ssl.
everything works fine except that some uri are still served via http.
such as , secure/viewavatar, images/icons/issuetypes/story.svg.
Did I lost some things to configure?
Nic Brough -Adaptavist-
November 25, 2017
Have you set the base url to https ?  And redirected http to it?
Cheng Qiu November 27, 2017
yes. base url was set correctly.
And rewrite settings of apache was set after proxy settings. Does this matter?  Should I put it before proxy settings ?
November 27, 2017
Ok, the other thing that can do this is missing the port, proxy and security settings in the connector - do you have those in your server.xml ?
Cheng Qiu November 30, 2017
I have not modified server.xml yet. Actually I do not know where it is.
And I found that the http resources were return with 403 so that they were not redirected. I have sent email to my host provider to query about this issue.
But I'd like to take action on server.xml you mentioned first.
Where can I find guides about how to set server.xml?
Andy Heinzer
December 1, 2017
That file exists in the $JIRAINSTALL/conf/ directory.
As for guides on how to configure this, since you mentioned using Apache to handle SSL, I would recommend this guide:  Integrating JIRA with Apache using SSL.
This guide provides some sample configurations that should be setup for that kind of configuration.
December 2, 2017
Thanks Andrew!
Cheng Qiu December 3, 2017
@Nic Brough -Adaptavist-@Andy Heinzer
Thanks. It's working!
Really appreciate your help
