I've been trying to use JIRA project automation to copy some xRay test plan fields when I create test execution from that test plan (usually with specific status) with no luck but the program itself inherits some field values like Fix Version/s, Enviroment... and Test Plan!.. but I can't use the action to copy a field from either the Trigger issue or Parent issue.
What am i missing?
Thnkas in advance
Nuno
While you may find some users on here familiar with XRay for app specific questions it's usually best to submit a ticket directly with them. Once you have an answer though I do recommend sharing it back on the community for future people when they are searching!
Here's the support page: https://jira.getxray.app/servicedesk/customer/portal/2/user/login?destination=portal%2F2
Best,
Clark
Hi @Nuno Fernandes !
Have you received any answers for your question you could share here?
I have a similar problem but I am not able to login into XRay to follow the link provided at the thread above.
