I have some custom dropdowns, which I didn't select to be required fields. I accidentally selected "none" on two of them and now they've disappeared from the ticket. I've since gone in and made those dropdowns required fields meaning I can't do it again!
Anyone got any idea how I can get the dropdown back on the two tickets that I selected none on?
On the "where is my field" section I get this info but I don't know how to set the value as it's not appearing?!
Field value | The field 'Requirement Size' does not have value for issue DITS-2 and will not be displayed on the view issue page. Set value for that field so that it shows up. |
Hollie
I solved this by clicking Admin->Add field and then searching for my field.
Found this article gave me a helping hand!! https://community.atlassian.com/t5/Jira-questions/Why-is-custom-field-not-displaying-on-selected-screens/qaq-p/674360/jump-to/first-unread-message
A field will not appear on the view screen if it has no value. That is how Jira works. You need to set a value for it in the Edit screen.
