Reverse proxy not working for Jira
elmer25 October 7, 2018
I am using a Windows Server 2016 with an Apache HTTP Server acting as the reverse proxy to the Jira server.
When I attempt to connect to the jira instance (a subdomain) on my domain, I get a 503. When I attempt to connect to http://jira.mydomain.com, the request is redirected to https://jira.mydomain.com which is expected.
The httpd.conf includes the following LoadModules plus additional default modules.
LoadModule proxy_http_module modules/mod_proxy_http.so
LoadModule proxy_module modules/mod_proxy.so
LoadModule proxy_ajp_module modules/mod_proxy_ajp.so
 In my vhosts.conf files, I have the following defined. Please note there are 3 blocks for VirtualHost and the Jira configuration is the 2nd block.
<VirtualHost *:80>
ServerName <subdomain1>.mydomain.com
DocumentRoot C:/Apache24/htdocs
<Directory "C:/Apache24/htdocs">
Require all granted
</Directory>
RewriteEngine on
# Redirect all traffic to https (except health check)
RewriteCond %{HTTP:X-Forwarded-Proto} !https
RewriteCond %{HTTP_USER_AGENT} !^ELB-HealthChecker
RewriteCond %{HTTP_HOST} !^localhost
RewriteRule ^.*$ https://%{HTTP_HOST}%{REQUEST_URI} [R=301,L]
# # if request is for admin, load admin.html
# RewriteRule ^admin/ admin.html [L]
RewriteRule ^/app$ https://%{HTTP_HOST}/app/ [R=301,L]
# everything else gets routed to index.html
RewriteCond C:/Apache24/htdocs%{REQUEST_URI} !-f
RewriteCond C:/Apache24/htdocs%{REQUEST_URI} !-d
RewriteCond %{REQUEST_URI} !^/app/
RewriteRule ^(.*)$ /index.html [L]
# Set up proxying
ProxyPreserveHost off
ProxyPass /app/ http://localhost:8080/app/
ProxyPassReverse /app/ http://localhost:8080/app/
#Set to gzip all output
SetOutputFilter DEFLATE
#exclude the following file types
SetEnvIfNoCase Request_URI \.(?:exe|t?gz|zip|iso|tar|bz2|sit|rar|png|jpg|gif|jpeg|flv|swf|mp3)$ no-gzip dont-vary
#set compression level
DeflateCompressionLevel 9
#Handle browser specific compression requirements
BrowserMatch ^Mozilla/4 gzip-only-text/html
BrowserMatch ^Mozilla/4.0[678] no-gzip
BrowserMatch bMSIE !no-gzip !gzip-only-text/html
SetEnvIf User-Agent ".*MSIE.*" nokeepalive ssl-unclean-shutdown downgrade-1.0 force-response-1.0
</VirtualHost>
<VirtualHost *:80>
ServerName jira.mydomain.com
RewriteEngine on
# Set up proxying
ProxyRequests Off
<Proxy *>
Require all granted
</Proxy>
ProxyPreserveHost On
ProxyPass / ajp://localhost:8081/
ProxyPassReverse / ajp://localhost:8081/
</VirtualHost>
<VirtualHost *:80>
ServerName confluence.mydomain.com
RewriteEngine on
# Set up proxying
ProxyPass / http://localhost:8090/
ProxyPassReverse / http://localhost:8090/
</VirtualHost>
 The Jira server.xml file has two Connectors
<?xml version="1.0" encoding="utf-8"?>
<Server port="8005" shutdown="SHUTDOWN">
<Service name="Catalina">
<Connector port="8081" maxThreads="150" minSpareThreads="25" connectionTimeout="20000" enableLookups="false"
maxHttpHeaderSize="8192" protocol="HTTP/1.1" useBodyEncodingForURI="true" redirectPort="8443"
acceptCount="100" disableUploadTimeout="true" bindOnInit="false" scheme="http"
proxyName="jira.mydomain.com" proxyPort="80"/>
<Connector port="8009" URIEncoding="UTF-8" enableLookups="false" protocol="AJP/1.3" />
<Engine name="Catalina" defaultHost="localhost">
<Host name="localhost" appBase="webapps" unpackWARs="true" autoDeploy="true">
<Context path="" docBase="${catalina.home}/atlassian-jira" reloadable="false" useHttpOnly="true">
<Resource name="UserTransaction" auth="Container" type="javax.transaction.UserTransaction"
factory="org.objectweb.jotm.UserTransactionFactory" jotm.timeout="60"/>
<Manager pathname=""/>
<JarScanner scanManifest="false"/>
</Context>
</Host>
<Valve className="org.apache.catalina.valves.AccessLogValve"
pattern="%a %{jira.request.id}r %{jira.request.username}r %t &quot;%m %U%q %H&quot; %s %b %D &quot;%{Referer}i&quot; &quot;%{User-Agent}i&quot; &quot;%{jira.request.assession.id}r&quot;"/>
</Engine>
</Service>
</Server>
I have stopped and restarted the Apache HTTP Server and the Jira service after these changes were made.
Thank you for any insight you might have on where this may be mis-configured.
JP _AC Bielefeld Leader_
October 8, 2018
Hi Jim,
you redirect every request to https, but you didn't setup any vhost for port 443 (https)...
Best
JP
elmer25 October 9, 2018
JP, Thank you and you are correct on the redirecting to https inside the Apache conf. The redirection is to the AWS Load Balancer which is listening on port 443. From the load balancer, the target is back on port 80. There is no redirect to 443 from the load balancer. As such all requests from the Load Balancer to the target is on port 80.
