SLA per group when creating issues by agents.
Soukaina IBALINE
I have agents creating problem issues, and I have clients creating service requests and incidents. In the condition I mentioned, if this client belongs to this organization, use this SLA. But how can I specify the group and say if the group is X, use this SLA?
Serge Calderara
hello @Soukaina IBALINE ,
The SLA rule is essentially based on a set of criteria that need to be all match in order to be valid.
There is no direct way to associate an SLA with a group
The only place you can do that is from the initial SQL condition where you can specify a JQL querry and at this stage you can specify the group membership
regards
Soukaina IBALINE
hey @Serge Calderara ,
Ok , can you share with me this JQL querry?  .
I thought it would be a function like  ' if the reporter is member of group X , use this SLA '
regards
Serge Calderara
create a new SLA and name it according to your JQL return data, then apply the goal as below
Soukaina IBALINE
Hi @Serge Calderara
it does work, thank you .
regards
Vitaly_Berezovsky_SaaSJet
Hi @Soukaina IBALINE
I advise you to try our Jira addon SLA Time and Report for this purpose.
You can bind an SLA to a specific project or certain ticket parameters to trigger the right SLA upon matching.
I hope I understood your question correctly!
FREE
