ScriptRunner - keep track of how long an issue has been in a status
Roberto L
February 2, 2018
Hello Community,
I have been trying to figure out a way to have a custom field that keeps track of how long an issue has been in a certain status.
I have a Story issue type with Status: Open, In Review, In Progress, Done
I want to find a way such that I have 4 custom fields that displays how long the issue stayed in each status.
  • Open Time
  • In Review Time
  • In progress Time,
  • Done Time
I have not been able to find a way to do so still.
Would anyone know how to achieve this?
Thank you!!
-Roberto
Markos Stefanou March 2, 2018
If you want to go at it the hard way, you need to add in your post function of each transition the current time and then calculate the difference between them and set the result in another field.
You would then need to do the following calculation for the new field:
(issueCreate.getTime() - linkedResolve.getTime())/(1000*60*60)
(The division differs depending whether you need the time in days, hours, minutes, seconds etc)
However, there are a number of addons that track time (even some free ones) that are probably much, much, MUCH better than reinventing the wheel yourself.
Time Reports for Jira
Issue History Collector
Status History
We are using another one named "Time In Status" for our instance.
Alexey Matveev
February 2, 2018
You would need to use ChangeHistoryManager. You can find more info here:
https://community.atlassian.com/t5/Jira-questions/How-to-get-assignee-change-history/qaq-p/453152
