×Hi community,
I would need some hints/help with a use case I would like to implement with scriptrunner.
This is the situation:
I do have a board reflecting costs and budget for education. Within this board there are 2 different subtask issue types:
The issue "Course" consists of a custom field "Total course costs". The issue type "Subtask" consists of a custom field "Budget".
I would like to populate the sum of the field "Total course costs" of all "Course" issues in status "Geplant" and write/populate this amount to the "Subtask" issue in status "Geplant". Please find the screenshots attached.
What would be your recommended way to implement this?
Any help/hints appreciated.
Thanks in advance.
Best
Stefan
Could solve the problem with a lot of snippets and "try and error". Might not be the most professional script but as I am not a developer I am proud it does what it should:
Still any feedback/hints for improvement appreciated:
// gets the value of import com.atlassian.jira.component.ComponentAccessor
import com.atlassian.jira.issue.IssueManager;
import com.atlassian.jira.event.type.EventDispatchOption
import com.atlassian.jira.bc.issue.search.SearchService
import com.atlassian.jira.issue.search.SearchException
import com.atlassian.jira.web.bean.PagerFilter
def cfManager = ComponentAccessor.getCustomFieldManager()
def issueManager = ComponentAccessor.issueManager
// get all changes from event
log.warn(event)
// defines the issue where customfield will be selected
//def course = event.issue as MutableIssue
def isCourse = event.issue.issueType.name == "Course"
//log.warn("Course issue/trigger: " + course)
log.warn("isCourse: "+ isCourse)
//define custom field "Total course costs"
def cfCourseCosts = cfManager.getCustomFieldObject("customfield_xxxxx")
//define customfield "budget"
def cfBudget = cfManager.getCustomFieldObject("customfield_xxxxx")
//get issue to be updated (Budget Subtask)
MutableIssue budgetIssue = issueManager.getIssueByCurrentKey("KEY-xx")
def changeLog = event?.changeLog
log.warn("changeLog "+changeLog)
//check if either Field "Preis" or "Participants" changed
def changeItems = changeLog.getRelated("ChildChangeItem")
def field = changeItems.field[0]
def isPreisChange = field == "Preis"
def isParticipantsChange = field == "Participants"
log.warn("isPreisChange: "+isPreisChange)
log.warn("isParticipantsChange: "+isParticipantsChange)
def user = ComponentAccessor.jiraAuthenticationContext.loggedInUser
def searchService = ComponentAccessor.getComponentOfType(SearchService)
// The JQL query you want to search with
final jqlSearch = "project = XXX and issuetype=Course and status = Planning"
// Parse the query
def parseResult = searchService.parseQuery(user, jqlSearch)
if (!parseResult.valid) {
log.error('Invalid query')
return null
if(isPreisChange || isParticipantsChange) {
try {
// Perform the query to get the issues
def cumulativeCourseCosts = (Double) 0
def results = searchService.search(user, parseResult.query, PagerFilter.unlimitedFilter)
def issues = results.results
log.warn("issues: "+issues)
// log.info("result: " + issues)
issues.each {
// log.info(it.key)
def costs = (Float) it.getCustomFieldValue(cfCourseCosts)
log.warn(costs)
cumulativeCourseCosts = cumulativeCourseCosts + costs
log.info("current cumulative: " + cumulativeCourseCosts)
log.info("final calculation of course costs: " + cumulativeCourseCosts)
// issues*.key
//set value of budget field to newly calculated/current budget
budgetIssue.setCustomFieldValue(cfBudget, cumulativeCourseCosts)
//update issue
issueManager.updateIssue(user, budgetIssue, EventDispatchOption.DO_NOT_DISPATCH, false)
//log.info(costArray)
} catch (SearchException e) {
e.printStackTrace()
null
Hi @Stefan Salzl ,
Not the complete or correct answer to your question, but in Automation for Jira it is also possible to add values in a numerical field.
We had a situation at a customer where they use the following formula in Excel: ($D6+$E6+$F6+$G6)/2
This we recreated in Automation for Jira with
({{issue.Technical Standards}} + {{issue.Skills Capability & Training}} + {{issue.Scope & Complexity}} + {{issue.Risk Factors}}) /2
to include in 'edit issue'. See also the picture.
Maybe you may find this option useful.
Regards, Marco Brundel
Hi @Marco Brundel ,
I would love to solve this with A4J. Unfortunately it‘s not an option as this is on Server and the plugin is not installed.
Thanks anyways for your effort.
Best
Stefan
