Strange JavaScript problem in create screen
TechnicalS February 10, 2014
Hello Support,
on a create issue screen a javaScript is not loading when we change issue type. This following script is added to the field "addiotnal hardware information" for the issue type "generic services":
<script type="text/javascript"> // <![CDATA[ env = document.getElementById('customfield_11400:1'); if (env) { target = document.getElementById('customfield_11403').parentNode; target2 = document.getElementById('customfield_11402').parentNode; if (env.value == 11211) target.style.display='none' && target2.style.display='none'; env.onchange=function() { if (this.value != 11211) { target.style.display = ''; target2.style.display = 'none'; target.value="enter message here"; } else { target.style.display='none'; target2.style.display=''; } } } // ]]></script>
The default issue type when we want to create an issue is "service request" and has a different field configuration. When we change the issue type to "generic services" the javascript does not work. I try to put the script in all field configurations but it still not works. We found several other pages where this problem is the same but the version of our jira is 6.0.8. Can you help us? Best regards Toni
Nitram
February 20, 2014
This may help you I think,
please check this answer
https://answers.atlassian.com/questions/47843/strange-javascript-problem-in-create-screen
Hope this helps you.
TechnicalS February 19, 2014
We still need this to be done
Nadir MEZIANI
February 11, 2014
I think that is the same problem in JIRA 5.2.8. To resolve this problem we have disabled the create issue popup.
To disable the create issue popup add this script in the banner.
&lt;script type="text/javascript"&gt;
//To disable the  create issue popup
AJS.$("#create_link").removeClass("create-issue");
&lt;/script&gt;
Look, this link it can help you
How to disable Create Issue popup
TechnicalS February 12, 2014
thanks very mich for reply. But we do not want to disable the create issue popup.
Kind regards
Toni
