We've encountered a quite annoying issue within Insight custom fields. When we exceed the number of characters that are shown within an Insight custom field, we are unable to distinguish some objects from each other (see screenshot down below). I would have expected that when I hover over the object within the CF, the full text would be shown in a hover box, although this is not the case.
Does someone know a solution/workaround for this?
Thanks in advance!
Nigel
Add a feature request for this in the Atlassian support.
Otherwise, you may need to create a new attribute with shorter names which you use when editing the Insight field. You can setup which attributes to use in the custom field's Insight configuration. ("Filter objects with attributes")
