Hi Community! 👋🏼
I'm looking for an automation rule (can be scheduled) that transitions the testing ticket (separate issue type) of a specific release to f.ex. "ready to test" status, when all other issues in that release are set to "done".
I'm having issues with how to check if all except for one ticket in a release are set to done (this should trigger the transition).
Thanks!
-Kaj
Couldn't really find a nice way to achieve the behaviour you described but something like the following might work?
Not great that it needs to execute the JQL twice (look up action and JQL branch) but can't come up with a better alternative.
Hope this helps.
Eric
Hi @Eric
Thank you for your suggestion.
Indeed not the cleanest, but thank you so much for looking at this!
I will see if I can solve it differently, and otherwise try your solution.
Thanks again!
-Kaj
