I love that JIRA Service Desk automation gives me the ability to create a linked issue in my R&D projects. But it looks as if we are limited on the fields that are easily copied from the Service Desk issue to the linked issue. For example, I would like for the priority field along with a custom field to be copied to the new linked issue in my R&D project so that it will the issue will sort correctly for review. Is there any way to include these values? If not in base which add-ons do you suggest to perform this action.
The out of the box automation is unfortunately very limited, check out Automation for Jira https://marketplace.atlassian.com/apps/1215460/automation-for-jira?hosting=cloud&tab=overview
They also have a separate Lite version for Cloud which is free and doesn't run on a trial license. You're instead limited to 300 rule executions per month.
