What tools do I need for Jira if I use SpecFlow and Jenkins?
Razvan Prepelita
June 10, 2021
Hi
We want to integrate manual testing and automated testing in Jira.
We use Specflow in .Net with Nunit and Jenkins
In Jira it's installed the Zephyr plugin:
"Zephyr for Jira - Test Management for JIRA (Server) 2000 Users: Commercial License"
From my research to integrate everything we will need also:
1. Cucumber for Jira(is this necesary?)
2. BDD feature for Zephyr should be enabled
3. Zephyr Squad plugin
Did I understand correctly? Is it another way to integrate them?
Is this working also on Jira installed on our server, not in the cloud?
Thanks.
Nick Iles [AssertThat]
Hi
You can integrate with Jira using the AssertThat BDD & Cucumber plugin for Jira.  We have a number of integrations available including a Jenkins plugin, more details on integration can be found here.
The plugin will enable you to write and link your BDD scenarios to Jira User Stories.  Automated test results can be imported into Jira using the plugin so they are easily accessible to all.  Manual test execution is also available within the plugin.
Please get in contact if you would like to discuss further and we can setup a demo
Best Regards
Nick
Marketplace Vendor for AssertThat
support@assertthat.com
