When I have multiple sla, how to order issue by sla in a Kanban view (jira agile) of a service desk project ?
Tommy Tellier March 27, 2014
I see that i can make a filter but i can'tmake a filter by column. So i need to have a filter how use sla using all I want to do something like this :
project = Support
if status = "En attente dune assistance" AND resolution = Unresolved ORDER BY "Temps écoulé pour la première réponse"
if status= "En attente dun tri" AND resolution = Unresolved ORDER BY "Temps écoulé pour obtenir de l'assistance"
If I use a case :
order by CASE sla(ocfv.content,'')
WHEN 'En attente dune assistance' THEN "Temps écoulé pour la première réponse"
WHEN 'En attente dun tri"' THEN "Temps écoulé pour obtenir de l'assistance"
ELSE "Temps écoulé pour obtenir de l'assistance"
END DESC
Can someone help me with that ? I just want to see the service desk in a kanban view order by SLAs.
EddieW
March 30, 2014
The sorting/order applies to the entire board. If you update the board's filter, then each individual column will be sorted by that order as well. There is not any means to sort individual columns. https://confluence.atlassian.com/display/AGILE/Configuring+Filters
The SLA's are just additional fields on each ticket so you can use the standard JQL to order on them individually.
ORDER BY "Time waiting for support"
But the logic of how to order on field A sometimes and B other times within the same query is much trickier (and certainly a corner use case). But heres the advice from my comment below based on Tommy's feedback:
The idea is to encapsualte your logic into the field, rather then JQL.
Use the JIRA Script RUnner plugin and add the custom field. Write Java or Groovy to look at the status and resolution, and set the feild to SLA A, or SLA B. Jamie has lots of great example scripts bundled with the plugin, and also in the public wikispace for the project.
You would then ORDER BY that new custom field, and it would use the appropriate time for each issue.
If you want to go a step further you can write your own custom field (not field type) and have it calculate the value using any logic you wish. That single field can then be used for searching. https://developer.atlassian.com/display/JIRADEV/Custom+Fields+in+JIRA
Tommy Tellier March 30, 2014
Hi Eddie, i know that i'm not able to sort individual columns but did you know if i'm able to create a JQL filter who will sort correctly with this limitation.
EddieW
March 31, 2014
Sorry @Tommy.
The limitation being an sort on field A sometimes, but sort on B others?
I am not aware of JQL's ability to support that in general (throwing Service Desk aside for the moment). In general its a twist in paradigm to say for ISSUE-1 Field A is used to order on the same board that ISSUE-2 is sorted just above it based on FIeld B. But I think in the context of SLA I can see where you are going.
(if I still am missing what you're asking please let me know! :) )
But I can think of a customization that _i think_ is what you are trying to accomplish. But would involve a scripted custom field. The idea is to encapsualte your logic into the field, rather then JQL.
