I have a custom field that was created by someone, this custom field appears in a Create Issue form. The field name is Team I located the field in custom fields but I cannot see where the "Team" values are being defined it's a multiple field box.
Thank you for any help.
Best regards,
You could check where the field is coming from and what options are available. You'll need to be a Site Admin to do this:
If the field is "locked" it might be a custom field from an app - such as Portfolio, which has a Team field. You'd need to manage teams from within Portfolio to add or remove them.
Ste
