I am using Cucumber in my testing framework and I use your API to create the tests in Jira-Xray, using the Import Test API
My surprise comes when I run my automation in Jenkins (using the XRay plugin), and see that the tests are run twice! Once because of the Jira test, and twice because of my feature file.
Facing that, I thought that I could delete the "Export Test" part from Jenkins, import the tests in Jira everytime I run them, and then keep the "Import results". But then it turns out that it does not like the report.
So my question is (after two days investigating), is there a way of having the tests in Jira and in the feature file, and at the same time, every tests just run once, plus the reports as well?
Thanks a lot! :)
Hello Danial,
could you please ecplain how you run your automation tests with Jenkins i'm so curious to know thanks a lot ( if you have screen shoots it weel bee great)
Hi Daniel,
We advise you to follow this follow: https://confluence.xpand-addons.com/display/XRAY/Testing+with+Cucumber#TestingwithCucumber-StandardCucumberworkflow
You need to export the Tests from JIRA, so they can be tagged properly with the issue keys, so that we can report correctly the results afterwards.
Before exporting Tests from JIRA (i.e. generating the feature files), make sure that the workspace directory, where you export them to, does not have any feature files (you may add some step in Jenkins for that).
Best regards,
Xray Team
Both links, from Jose Domingues and Michael Rose, are broken. :(
